Choose how the tbd 16 connects to your computer or network.
FUNC1 → Settings → WIFI Settings
The screen shows the current mode, SSID (if applicable), and mDNS name you can use to reach the WebUI in a browser.
Mode Description
Access Point (open) The tbd 16 creates its own open WiFi network you can join from any device
USB Network (NCM) Connect over a USB-C cable — the computer treats the device as a network interface (IP: 192.168.4.1)
Select a mode and press to switch. The device reboots to apply the change.
Once connected, open the WebUI in a browser.
