How audio signals route through the tbd 16 from tracks to output.
Overview
The tbd 16 uses a send/return effects architecture with per-track mixer parameters, group-level offsets, two global FX buses (FX1 Delay, FX2 Reverb), a master sum-bus chain (compressor → drive → volume), and a final stereo output stage with always-on soft-clip safety.
The sequencer handles all step data, parameter locks, and automation, sending note and CC data to the audio engine internally. The audio engine runs the synth voices, effects, and audio output.
The three bus targets — FX1, FX2, and Master — appear in the track ring at positions 17, 18, and 19. Reach them via the Mixer Select Overlay (hold FUNC4) or the left-arrow chain from Track 01.
Signal Flow Diagram
│                   PER-TRACK (×16)                       │
│  Sequencer Step                                         │
│  Note + Velocity + P-Locks + Automation                 │
│  │   Synth Engine      │  (runs on P4)                  │
│  │   TBD03 / Wavetable │                                │
│  │   Rompler / Polypad │                                │
│  │   Track Mixer       │                                │
│  │   Level  [0-127]    │  ← can be p-locked per step    │
│  │   Pan    [0-127]    │  ← can be p-locked per step    │
│       │    │    └─→ FX2 Send [0-127] ──→ FX2 Bus       │
│       │    └──────→ FX1 Send [0-127] ──→ FX1 Bus       │
│   Dry Signal → Group Mixer                              │
│    GROUP MIXER        │ │   FX1 BUS    │ │   FX2 BUS    │
│                       │ │   (Delay)    │ │   (Reverb)   │
│  Group 0: Tr 1-2      │ │              │ │              │
│  Group 1: Tr 3-8      │ │ Time         │ │ Time         │
│  Group 2: Tr 9-11     │ │ Sync         │ │ Lowpass      │
│  Group 3: Tr 12-15    │ │ Freeze       │ │ Level ──────┐│
│                       │ │ Stereo Width │ │             ││
│  Each group applies:  │ │ Feedback     │ └──────┬──────┘│
│  • Volume offset      │ │ FX2 Send ────────→   │       │
│  • Pan offset         │ │ Level ──────┐│        │       │
│  • FX1/FX2 offsets    │ └──────┬──────┘│        │       │
│                     MASTER CHAIN                        │
│  Dry Mix + FX1 Return + FX2 Return                      │
│  │  Compressor (sees   │   Page 2/3 of Master           │
│  │  dry mix only — FX  │   Threshold / Ratio / Atk/Rel  │
│  │  returns skip the   │   MakeUp / Mix / SC-LPF        │
│  │  side-chain)        │                                │
│  │   Drive             │   Page 4 — soft saturation     │
│  │   off..heavy        │   bypassed at default (off)    │
│  │   Master Output     │   Page 1 — OUTPUT              │
│  │   Volume (fader)    │   off / 0dB unity / +12dB      │
│  │   Mute  [on/off]    │   ← Global Sound Knob 4 click  │
│  │   Delay return      │   FX1 return level             │
│  │   Reverb return     │   FX2 return level             │
│  │  Output soft-clip   │   stmlib::SoftClip — ALWAYS ON │
│  │  (per-channel)      │   Hard ceiling at ±1.0;        │
│  │                     │   transparent at safe levels.  │
│       STEREO OUTPUT  (TI AIC32X4 codec)                 │
Track Level
Each of the 16 tracks has its own synth engine running on the P4 and four mixer parameters controlled by the Pico sequencer:
Parameter Range Default Description
Level fader (off / 0 dB / +12 dB) 64 = unity Track output volume — squared curve, wire 0 is silence, wire 64 is unity gain, wire 127 is +12 dB
Pan 0–127 64 (center) Stereo position
FX1 Send 0–127 0 Send level to FX1 (Delay)
FX2 Send 0–127 0 Send level to FX2 (Reverb)
The OLED renders Level as an honest dB readout — off at wire 0, -…dB below unity, 0dB at wire 64, and up to +12dB at wire 127. The same fader curve is used by FX returns and Master Volume, so gain language is consistent everywhere on the device.
All four mixer parameters can be parameter-locked per step, allowing rhythmic volume changes, panning automation, and per-step FX send variations.
Edit these on the Track Mixer screen or the individual track pages of the Mixer screen.
Track Groups
Tracks are organized into 4 groups, each with level/pan/FX offset controls accessible on the Mixer screen’s group page:
Group Tracks Default Assignment
Group 0 1–2 Kicks
Group 1 3–8 Percussion / Rompler
Group 2 9–11 Synths
Group 3 12–15 Wavetable / Poly
Group offsets are applied on top of individual track mixer values. Each group has: Volume Delta, Pan Delta, FX1 Delta, FX2 Delta, and Filter Delta.
FX Buses
FX1 — Delay
3 pages of parameters (12 total). Key parameters:
  • Time — delay time
  • Sync — tempo sync mode
  • Freeze — freeze buffer
  • Stereo Width — stereo spread
  • Feedback — delay feedback amount
  • FX2 Send — sends delay output into the reverb (FX chain cascade)
  • Level — FX1 output level (also accessible as Knob 2 on Global Sound)
FX2 — Reverb
1 page of parameters (3 total):
  • Time — reverb decay time
  • Lowpass — reverb tone/damping
  • Level — FX2 output level (also accessible as Knob 3 on Global Sound)
FX2 receives signal from both individual track sends and from FX1’s FX2 Send parameter, enabling delay-into-reverb chaining.
Master Chain
The master chain processes the combined stereo mix (dry + FX returns) across four pages on the Master screen. The order in the DSP is:
  1. Sum bus — all 16 tracks plus FX1 + FX2 returns mixed.
  2. Compressor (Pages COMPRESSOR A + COMPRESSOR B) — sees the dry mix only; FX returns skip its side-chain so reverb/delay tails don’t duck. Threshold, Ratio, Attack, Release on Page 2; MakeUp, Mix, SC-LPF on Page 3.
  3. Drive (Page DRIVE) — analog-style soft saturation. Bypassed at default (knob = off); pushes into musical clipping when raised.
  4. Master Volume (Page OUTPUT Knob 1) — same squared fader curve as track levels. Wire 0 = silence, wire 64 (boot default) = unity, wire 127 = +12 dB.
  5. Always-on output soft-clip — stmlib::SoftClip per channel, transparent at safe levels, hard ceiling at ±1.0. This is the safety guarantee: no matter what you do upstream, the codec never sees a digital clip.
Page OUTPUT (Page 1, the landing page) groups the four live-performance controls — Volume, Mute, Delay return, Reverb return — so live tweaks never need a page change.
Clip metering — visible from anywhere
Two visual sources surface the master output level so you don’t have to leave whichever screen you’re on to spot trouble:
  • OLED header peak bar — visible on every page, between the BPM display and the Stp / Rec / Ply indicator. Fills left-to-right with the master peak. Solid (latched) flash = soft-clip is engaging. Latches ~½ second per over-peak so brief transients don’t get missed.
  • FUNC1 / FUNC2 LEDs (multi-zone) — the front-panel FUNC LEDs colour-code the post-soft-clip output level: dim green (safe, < −10 dBFS), bright green (healthy, −10..−5), yellow (caution, −5..−2), orange (ceiling, −2..−1), red (at clip, −1..0). A magenta latch flashes briefly when the soft-clipper actually engages. See Display Settings for the colour key reference.
Global Sound Quick Access
The Global Sound screen provides one-knob access to the four most important mix parameters:
Knob Controls Source
Knob 1 Input Level Track 16 mixer level (squared fader, off / 0 dB / +12 dB)
Knob 2 Delay Level FX1 return level (same squared fader)
Knob 3 Reverb Level FX2 return level (same squared fader)
Knob 4 Master Level Master Volume (same squared fader); click toggles master mute
Where Parameter Locks Apply
Parameter locks (p-locks) and automation inject at the track level, before the signal reaches the mixer and effects:
  • Audio parameter p-locks — modify synth engine parameters per step (up to 24 parameters)
  • Mixer parameter p-locks — modify track level, pan, and FX sends per step (up to 8 parameters)
  • LFO/Random automation — continuous modulation applied per step, combined with p-lock values
The evaluation priority is: P-Lock value (or track default) + Automation value + MIDI map value, clamped to the parameter range.
MIDI Signal Flow
The Pico sequencer generates MIDI data that routes to both the internal P4 synth engines and external MIDI ports:
Sequencer → Note/CC data
    ├──→ P4 (internal synth engines via SPI)
    ├──→ TRS MIDI 1 Out
    ├──→ TRS MIDI 2 Out
    ├──→ USB Host MIDI Out
    └──→ USB Device MIDI Out
Each output port can be independently configured as None, Sync, Notes, or Sync+Notes via MIDI Settings.
External MIDI input follows the reverse path, with received notes and clock routed to the sequencer.
