Visual feedback for every solenoid beater — plug-and-play, no soldering, no electronics know-how required.
Coming soon Releasing soon. This page will be updated with detailed installation and usage notes.
What it is
The LED Splitter is a small inline adapter that sits between an automat output and a solenoid beater. It passes the trigger signal through to the solenoid as normal, and lights an LED on every hit. For the first time, audiences can see both the physical movement and a clear visual signal for each trigger.
What’s in the set
- 12 LED Splitters — one per output on an automat controller.
- Fully passive — plug between output and beater, no additional power required.
- Colour: white LED (matches the dadamachines aesthetic).
Availability
A set of 12 LED Splitters is 39 € + VAT.
See also
- automat controller — the controller the splitters plug into.
- Elements — solenoid beaters and other driven elements.
